Removing and replacing the rightside PW motor, theirs a retaining plate with holds in the cable assy to the motor housing. By removing this plate, do I just slide out the cable assy and place it inside the new motor housing? I went to the Dodge dealership and their responce was they replace the whole harness assy as one unit because if the motor and cable assy isn't "timed" correctly the window will probably only go partially up or down, or go down and not go up.
SPONSORED LINKS
Monday, September 27th, 2010 AT 3:02 PM
