1996 Dodge Caravan windows wont go up
AURA HARRIS
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
One day while i was trying to roll the window up it made a loud roaring noise and started clicking and stopped moving and hasn't moved since. that was the driver's side window. A few days after that my passenger side stopped working and now the back windows wont close. the control panel on the door doesn't control anything. HELP
Nov 27, 2008 at 7:15 AM
  • 110,244 POSTS
Hi:
The grinding sounds like the gears on the motor may have gone bad. As a result, the motor may have shorted causing a fuse to blow or damage to the switch. Check the fuse first and if it's good, you will have to remove the door panel to check the switch and the motor.
PS: Let me know what you find.
Nov 27, 2008 at 1:01 PM
