2003 Dodge Caravan power window not working
OLDCARMARK
Electrical problem
2003 Dodge Caravan
On my 03 Dodge Caravan the passenger power window stopped working.Thank goodness its in the üp"position.I understand the windows are on a resetting circiut breaker so there is power on.The interior lights do not dim when the switch s depressed so I think the motor is NOT seized.How can I check for what the problem is?Neither master or door switch will operate the window.Thanks
May 9, 2009 at 5:16 AM
  • 110,251 POSTS
What you need to do is remove the door panel and check to see if the motor is getting power. If it is, the motor will need replaced. If there is no power, then it could be the master switch or a break in the power supply.
May 12, 2009 at 2:56 PM
