Starter not working
DPAZ
  • 1997 DODGE CARAVAN
  • 6 CYL
  • 136,000 MILES
97 Grand caravan with a 3.8l V6 stalled while driving. When I pulled over, the car tryed to start but I when I put gas by the pedal it turned off. Now it wont start,the van just sits. When I turn the key, the dash lights and needles work, radio, etc... I do not hear any noise from the gas pump, or clicking from anywhere. I checked for a code, but nothing no code stored either.I put a voltmeter on the new battery, and it is 13 volts. I have replaced the camshaft sensor and ignition switch. Any other suggestions?
http://www.justanswer.com/questions/ku4z-97-grand-caravan-not-start#ixzz0IiX51eHw&D
Tuesday, August 20th, 2019 AT 12:49 PM (Merged)
JDL
  • 16,098 POSTS
Hello, if the starter won't even crank, check the starter circuit. If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs--injector pulse--fuel pressure.
