1998 Dodge Caravan Starter Problem
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
JSF119F22
Intermittent starting problem.
My can seems to intermittently stop when I try to start it and then after leaving it sit for a day, it starts back up like there hasn't been a problem. This happens maybe once every other month or so. What could be the problem.
Mar 21, 2008 at 8:40 AM
BMRFIXIT
  • 19,053 POSTS
What do you mean
car stalls on you and will not start
or
you try to start but not crank
or
crank with no start
Mar 21, 2008 at 11:37 AM
JSF119F22
this happens every now and then - when I start the car - it will start then die - then I try to start it again and it would not crank at all. After letting it sit for a day or for a few hours - I will start it and it starts without a problem
Mar 24, 2008 at 12:46 AM
BMRFIXIT
  • 19,053 POSTS
have the starter checked and relay too
check battery and terminals
Mar 24, 2008 at 11:03 AM
JSF119F22
I just spent 1000.00 on a new starter, an alternator and also a new battery....based on what the dealer told me that they found. That didn't work
Mar 25, 2008 at 3:32 AM
BMRFIXIT
  • 19,053 POSTS
did they check the BCM
Mar 25, 2008 at 10:16 AM
