1985 Dodge Aries
SHEILA JACKSON
  • 1985 DODGE ARIES
1985 Dodge Aries
I have an 85 Dodge Aries I replace the alternator and battery now it stall out then won’t start again.
Friday, December 4th, 2009 AT 10:23 AM
Do below:
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Friday, December 4th, 2009 AT 11:44 AM
