Crankshaft sensor location?
TROYTIS
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • FWD
I bought a 93 grand am and put a timing chainin it and it won't start. It has fuel pressure a new crank sensor checked the coils checked the injector new plugs and fuel filter. It shows no engine codes any sugestions?
Monday, July 13th, 2020 AT 7:33 PM (Merged)
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
ALEXI
  • 4 CYL
  • 124,000 MILES
19 Crank Position Sensor Fault, Runs when it's cold but dies when it warms up, replaced a lot of sensors don't know what else to do.
MMPRINCE4000
  • 8,548 POSTS
I assume you have replaced the crank sensor?
Remove ign. Module and have it tested at most autoparts stores for free.
ALEXI
Well The module that under the cover, I already tested it at Auto Zone and it ran fine, I've heard you have to put some kind of a grease between the module and the cover. I was gonna try to replace oxygen sensor cause it didn't read on the scanner.
