Cranks, no spark and no start
79,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
LINDA GREEN
New battery, starter, solenoid, plugs. Will not start. I have coil, not changed yet.
Aug 29, 2018 at 10:38 AM
  • 110,248 POSTS
This could be the result of many things. Therefore, we need to narrow it down. For an engine to run, it must have compression, fuel, spark, and correct timing. Here is what I need from you: Read through this link and determine what is missing, spark or fuel. If both are present, then there is either a timing issue or low compression.
Let me know what you find and we will focus on that specific component or system.
Aug 30, 2018 at 11:42 AM
