Introduction
The ignition system must operate for your engine to run. If this system has issues, the engine can stall without warning or refuse to start altogether. In this guide we will go over the popular reasons of the entire ignition system to shut down. If you're having problems with just one cylinder, please use this ignition system testing guide.
Common Causes of Ignition System Spark Failure
1. Faulty Crankshaft Position Sensor (CKP)
By far, the most popular reason for an engine to lose spark is a crankshaft position sensor failure. This sensor is responsible for sending feedback information to the engine computer which produces a trigger signal to each coil at the correct time which ignites the fuel air mixture. Most of the time when this sensor fails it will not leave a trouble code, the engine computer just assumes there is a mechanical problem which is not rotating the reluctor on the crankshaft.
2. Ignition Fuse Failure
All ignition systems have a separate fuse that sends power to the ignition coil system, anytime you lose spark the first thing to check is the fuse, which is located in the fuse panel under the hood. If its not clear which fuse it is, please ask the 2CarPros communityto help find it in the engine control wiring diagrams.
3. Shorted Ignition Coil
If the fuse is blown chances are you have shorted ignition coil, but even if the fuse is okay this can still be the problem even on multi-coil systems. This is because the short can "shut down" the coil drivers inside the engine computer. Remove the ignition coils and test, begin by set your multimeter to Ohms. Touch the positive (+) and negative (-) terminals of the coil. The resistance should be between 0.4 - 2.0 ohms (varies by manufacturer). If it's out of range or infinite, the coil is bad.
4. Faulty Computer Main Power Relay
If this relay fails to supply power to the engine computer there will be no spark. Here are the names of the relay which may vary from each manufacturer.
- BMW / MINI - DME Relay (Digital Motor Electronics)
- Ford / Lincoln / Mercury - PCM Power Relay
- GM (Chevrolet, GMC, Cadillac, Buick, Pontiac, Oldsmobile, Saturn, Hummer) - ECM/PCM Relay
- Chrysler / Dodge / Jeep / Ram - ASD (Automatic Shutdown) Relay or PCM Power Relay
- Toyota / Lexus / Scion - EFI Main Relay, Circuit Opening Relay or IG1/IG2 Relay
- Honda / Acura - PGM-FI Main Relay (Relay 1 & 2) or ECM Relay
- Nissan / Infiniti - ECM Relay, Ignition Relay or IPDM (Intelligent Power Distribution Module) Relays
- Hyundai / Kia - ECM Relay or Main Relay
- Mercedes-Benz - ME-SFI Control Unit Relay
- Mazda - PCM Power Relay, Fuel Injection Relay or Ignition Relay
- Mitsubishi - ECM Power Relay
- Renault - Injection Relay or ECU Relay,
- Subaru - ECM Power Relay
- Suzuki - ECM Relay or Main Relay
- Volkswagen / Audi - ECU Relay (J271) or Power Supply Relay (J317
- Volvo - ECM Power Relay
You can test the relay, by following this guide or just swap it out for a new one.
5. Bad Ignition Control Module (ICM)
Some cars have an ignition control module while other have it "built in" to the engine computer. While receiving a signal from the engine computer it then outputs the "trigger" signal to the ignition coils, (This module is basically an amplifier). When this component fails the result is a "no spark" condition.
6. Bad Camshaft Sensor
Depending on the application, if a camshaft sensor goes bad it can cancel the output signal of the crankshaft sensor not allow the engine computer to receive the ignition signal. If you suspect this issue simply unplug the camshaft sensor and then re-test for spark.
7. Faulty Engine Computer
Some manufacturers have a trouble code for the failure of the engine computer coil drivers such as:
Unfortunately some manufactures do not have a trouble code for when the engine computer goes out, the solution is to swap the computer out for a rebuilt, reprogrammed unit.
Single Coil Systems (Older Cars)
1. Bad Points
A set of mechanical electrical points act as a "trigger" of the coil and can wear down closing the "dwell" setting and stopping the spark from occurring.
2. Ignition Rotor Failure
The ignition rotor spins acting as a pointer to each cylinder inside the distributor cap, when this part goes bad the ignition spark from the ignition coil grounds to the distributor shaft effetely canceling the spark.
3. Shorted Coil Wire
When a ignition coil wire goes bad it can burn up internally with no signs of problems for the outside of the wire creating an open circuit and no spark.
4. Burned Distributor Cap
From the ignition coil to the rotor there is the distributor cap, much like the coil wire once the connection is burned it will stopping the continuity between the coil and rotor.
Watch the Video!
Please watch this video of the job being done to glean additional helpful information.
Credits
This guide knowledge base was created by the 2CarPros Team. If you have a car repair question, you can ask the 2CarPros community for help. Please visit our 2CarPros YouTube Channel for more helpful repair videos.
