See if the following test is of any help.
SSD RELAY CONTROL CIRCUIT
Monitored & Set Conditions
Circuit is monitored with ignition on. Battery voltage above 10 volts. DTC will set if an open or shorted condition is detected in the ASD relay control circuit. This is a one trip fault.
Possible Causes
ASD Operation
(A14) Fused B+ Circuit
ASD Relay Resistance
(K51) ASD Relay Control Circuit Open
(K51) ASD Relay Control Circuit Short To Ground
PCM
Testing
1. Ignition on, engine not running. With the DRBIII(R) scan tool, actuate the ASD Relay. Is the ASD relay operating? If yes, see
INTERMITTENT CONDITION under SELF-DIAGNOSTIC SYSTEM. If no, go to next step.
2. Turn the ignition off. Remove the ASD relay from the Power Distribution Center (PDC). Ignition on, engine not running. Measure the voltage of the (A14) fused B+ circuits in the PDC. Is the voltage above 11.0 volts? If yes, go to next step. If no, repair the (A14) fused B+ circuit. Check and replace any open fuses.
3. Turn the ignition off. Remove the ASD relay from the PDC. Measure the resistance of the ASD relay between the fused B+ terminal and the ASD relay control terminal. Is the resistance between 60-80 ohms? If yes, go to next step. If no, replace the ASD relay.
In testing procedures Alpha/Numeric character in patientness i.e. (K4) designates circuit. After each repair procedure has been completed, reconnect all components. Perform POWERTRAIN VERIFICATION TEST VER-5 under VERIFICATION TESTS to ensure system is functioning properly.
CAUTION:
Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals resulting in poor terminal to pin connection. Install Miller Special Tool (8815) to perform diagnosis.
4. Turn the ignition off. Remove the ASD relay from the PDC. Disconnect the PCM harness connectors. Measure the resistance of the (K51) ASD control circuit from the PDC to the appropriate terminal of Miller Special Tool (8815). Is the resistance below 5.0 ohms? If yes, go to next step. If no, repair the open in the (K51) ASD relay control circuit.
5. Turn the ignition off. Remove the ASD relay from the PDC. Measure the resistance between ground and the (K51) ASD relay control circuit in the PDC. Is the resistance below 5.0 ohms? If yes, repair the short to ground in the (K51) ASD relay control circuit. If no, go to next step.
6. Before continuing disconnect the PCM harness connectors and check the related wiring terminals for corrosion, damage or terminal push out. Repair as necessary. Pay particular attention to all power and ground circuits. If there are no possible causes remaining, replace and program the PCM. See PROGRAMMING .
May 14, 2020 at 6:30 AM
(Merged)
