Crank but will not start
THISTHIS09
  • 12 POSTS
I am sorry I haven’t been able to get on to now, cables are good. It won’t do anything more now. Tried to turn manually just sounded like chain jumping. I red I shouldn’t have done that. After the fact.
Saturday, May 18th, 2019 AT 6:36 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, when you turned the engine over by hand did you feel any unusual resistance? There should be a little but the engine should smoothly turn and you should hear the valves opening and closing. How did it turn out?
Thanks,
Alex
2CarPros
Sunday, May 19th, 2019 AT 6:32 AM
HOLLAR HOMESTEADER
I have a 2007 Acadia that has a similar cranks but won't start issue.
It started to idle rough and after disconnecting various connectors and reconnecting them to see the effect, I discovered the root issue was a shorted cam position actuator wire pair near the connector. Unfortunately now the car just cranks but won't start. It has fuel to the fuel rail and spark. While using starting fluid, it blew a flame out of the intake. The only way that I figure it can do that is if a valve is open while it's firing a spark plug, which would mean that the spark timing is way off.
I've since changed the crank position sensor, tested all the fuel injectors to be good, and replaced the camshaft position sensors. I'm thinking that the electrical short may have fried the ECM, I've also bought and replaced that.
Does anyone have any suggestions? A ECM Pinout would also help so that I could verify wiring (like crankshaft position back to the ECM)
Please help.
Thanks
Wednesday, June 19th, 2019 AT 8:10 PM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the information that you requested, an Engine Control Module(ECM) Pinout with callout with wire colors. Please go through this Pinout chart and get back to us with how things turn out, please.
Thanks,
Alex
2CarPros
Thursday, June 20th, 2019 AT 6:27 AM
