My vehicle listed above is the LS model. the engine shut off while driving normally as If the key had been switched off. I have replaced the fuel pump, spark plugs and crank shaft position sensor. Also, tried swapping out the PCM. Still no fuel or fire, but 150 PSI compression on number one cylinder. The timing belt looks good. Any suggestions appreciated. Please help.
Mar 18, 2017 at 8:16 AM
