2016 Ford F-150 Coolant Temp Sensor Location
78,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
THERIOT
I need help finding the location or a diagram of the location for the coolant temperature sensor so that i can change it out. (Not the EB engine), just a regular trucck listed above (non turbo). Please help!!!!
Mar 18, 2023 at 7:07 AM
  • 110,248 POSTS
There is an engine coolant temperature sensor and a cylinder head temperature sensor. The ECT is at the rear of the engine and the CHT sensor is mounted on the cylinder head and under the intake manifold. See pic 1.
Pic 2 shows locations for both. However, most of these only have a CHT sensor. Pic 3 gives you a better view of the CHT location. Check the area indicated in pic 2 for the coolant temperature sensor.
Let me know if this helps.
See pics below
Mar 18, 2023 at 7:36 AM
Suggested Repair
Check the rear of the engine for the engine coolant temperature sensor. On many of these non-turbo trucks, only a cylinder head temperature sensor is used; it is mounted on the cylinder head under the intake manifold.
Conversation Summary
The owner of a 2016 Ford F-150 with a non-turbo engine asked where the coolant temperature sensor is located so it can be replaced. The expert explained that the engine coolant temperature sensor is at the rear of the engine, while the cylinder head temperature sensor is on the cylinder head under the intake manifold. The expert noted that most of these trucks have only the cylinder head temperature sensor and directed the owner to check the indicated locations.
