Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Sebring
Warning Lights
Oil Light
oil pressure
CHRYSLER SEBRING
CITYBILLY
MEMBER
1 POST
oil press light comes on sometimes when idling
Nov 24, 2007 at 11:20 PM
MERLIN2021
Experienced Mechanic
Get a test gauge, unscrew the oil sender, screw the gauge into the hole and start engine, note readings.
5-10 PSI at idle...less you need to figure out if pump is weak, or bearings need replacement...
Nov 25, 2007 at 1:09 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
