2002 Chrysler Sebring High Idle Brake Pull Fix
BUTTERFLY_ARS
Hello i have a 2002 sebring and when i brake it pulls back at me. When i start my car it accerlates pretty high. I was wonder what is wrong and if it is any expensive fix.
Thank you
Mar 13, 2006 at 1:39 PM
VANDRAGON
  • 298 POSTS
"when you push the brake it pulls back at you" do you mean that the pedal pushs back or becomes stiff?
that sounds like the power brake booster or vacume problem which could cause the engine to rev.
as for the engine rev it could be the throttle position sensor or sticking throttle cable. if you can locate the throttle cable, spray a little wd40 or rub a little oil on the cable up to the cable housing(do this with the motor off and cold) then get in the car and pump the gas pedal three or four times, then start the car. push the gas pedal a few times and see if it returns to normal idle.
Mar 19, 2006 at 12:48 AM
Suggested Repair
Check the power brake booster and vacuum system, which can make the brake pedal push back and raise engine speed. Also check the throttle position sensor and a sticking throttle cable. With the engine off and cold, lubricate the throttle cable up to the housing, pump the pedal several times, then start the car and confirm the idle returns to normal.
Conversation Summary
The owner of a 2002 Chrysler Sebring says the brake pedal pulls back when braking and the engine revs high at startup, and asks whether the repair is expensive. The expert asks whether the pedal pushes back or becomes stiff, and suggests a power brake booster or vacuum problem that could also cause the high rev. For the high idle, the expert suggests a throttle position sensor or sticking throttle cable and recommends lubricating the cable with the engine off and cold, then testing whether idle returns to normal.
