1998 Chrysler Sebring Fuel Gauge Drops
1998 ALL OTHER MAKES ALL OTHER MODELS
TIM
My daughter has a 1998 Sebring convertible and the fuel low light keeps coming on every 20-30 seconds and the needle on the gauge drops and comes back to normal (full, 2/3, 1/2 etc) This happens even though the fuel tank is full. The light sometimes flashes 3 times in a row and then back to the 20-30 second interval. Is this a sensor and if so where would it be in the tank or closer to the engine? Thanks
Nov 9, 2006 at 11:23 PM
BOOTDOG
  • 665 POSTS
the problem is gonna be the fuel sending unit. it's located in the gas tank and if it's like most other cars, it will be part of the fuel pump. your best bet is to call and find out if the pump is seperate from the sending unit. i know new fuel pumps can be pricey. what this unit does is send a signal to the fuel gauge to let u know the fuel level. hope this helped
Nov 10, 2006 at 4:52 AM
TIM
Appreciate the reply I was hoping I wouldn't have to drop the tank.
Nov 13, 2006 at 5:24 AM
Suggested Repair
Inspect or replace the in-tank fuel sending unit, which is often part of the fuel pump. Confirm whether the sender is sold separately before replacing the pump, since pumps can be costly.
Conversation Summary
The owner of a 1998 Sebring convertible reports the low-fuel light cycling every 20-30 seconds and the gauge needle dropping then returning even with a full tank. The expert attributes this to the fuel sending unit in the gas tank, commonly combined with the fuel pump, and suggests checking whether the sender can be replaced separately.
