2001 Chrysler Sebring Burning Oil
FEE2FINE
2001 CHRYSLER SEBRING 92,321 MILES V6 ENGINE
i AM CONSTANTLY HAVING TO PUT OIL IN MY CAR TO KEEP IT LEVEL. AFTER 1 OR 2 DAYS OF DRIVING THE OIL LIGHT COMES ON..I CHECK IT AND THE OIL IS VERY LOW. IT WILL ALSO SHUT OFF AND THE CK ENGINE LIGHT THEN COMES ON? i RECENTLY HAD AN OIL CHANGE AND THE LUBE TECH STATED THERE WAS JUST A SMALL AMOUNT OF LEAKAGE. wHERE IS ALL THIS OTHER OIL GOING? IT IS NOT ON THE GROUND..OR EVER IN MY DRIVEWAY. PLEASE ADVISE AS TO WHAT YOU THINK THE PROBLEM MAY BE? CAN IT BE REPAIRED?... OR SHOULD I GET RID OF THE CAR.
May 17, 2007 at 7:00 AM
BOOTDOG
  • 665 POSTS
if it's not leaking then you're burning it. this can happen, (for example), when the rings around the pistons wear allowing oil to enter the combustion chamber. in that case an engine overhaul or replacement will need to be done to fix it.
May 17, 2007 at 8:44 AM
Suggested Repair
If there is no external leak, the engine is likely burning oil, possibly because worn piston rings let oil into the combustion chamber. Repairing that typically requires an engine overhaul or engine replacement.
Conversation Summary
The owner of a 2001 Chrysler Sebring with a V6 and about 92,321 miles reports the oil level drops after one or two days of driving, triggering the oil light and sometimes a check-engine light and shutdown. A recent oil change found only a small leak, and no oil is visible on the ground. The expert says the oil is likely being burned, for example through worn piston rings, and that an engine overhaul or replacement would be needed to fix it.
