1997 Chrysler Sebring Belt Vibration
OMAICIN55
I have a 1997 Chrysler Sebring LXi. I had the serpentine belt replaced recently and I've noticed when the car is running i hear vibrating coming from that area. I was wondering if the serpentine belt could be loose?
May 12, 2006 at 2:41 AM
LOSONE
  • 1,616 POSTS
The only was the belt can be loose is if you had a bad tensioner. Grab the belt (engine off) with some gloves and pull. If you feel slack that won't go away, it's the tensioner. Good luck
May 12, 2006 at 6:46 AM
Suggested Repair
With the engine off and gloves on, pull the serpentine belt. If slack remains and will not go away, replace the automatic belt tensioner.
Conversation Summary
The owner of a 1997 Chrysler Sebring LXi hears vibration near a recently replaced serpentine belt and asks whether the belt is loose. The expert says a loose belt usually indicates a bad tensioner and advises pulling the belt with the engine off to check for slack that does not go away.
