1999 Chrysler Sebring Stalls
1999 ALL OTHER MAKES ALL OTHER MODELS
HKROMER
I have a 1999 Chrslyer Seabring JX 2.4L with 66,000 miles. After the cars runs about twenty minutes it suddenly stops running. One time I was drive with my foot pressing the accelerator and the car died. I checked with the dealer about any recalls and they assured me my vehicle was up to date. Any help would be greatly appreciated.
Jan 22, 2007 at 4:41 AM
  • 75,988 POSTS
Have the fuel pressure check-also can be a ICM,CPS,ASD relay or the computer itself.
Jan 22, 2007 at 5:06 AM
ZACKMAN
  • 4,202 POSTS
If you have never replaced the fuel filter, it is probably clogged. DC recommends that the filter be replaced every 30K miles. I don't think that the pump is bad especially with that low miles.
Jan 22, 2007 at 2:20 PM
Suggested Repair
Check fuel pressure and replace the fuel filter if it has not been changed (recommended about every 30,000 miles). If pressure is normal, also check the ignition control module, crankshaft position sensor, ASD relay, and the computer.
Conversation Summary
A 1999 Chrysler Sebring 2.4L with 66,000 miles dies suddenly after about 20 minutes of running, including once while the accelerator was pressed. Recalls were already confirmed current. Experts suggested checking fuel pressure and replacing a possibly clogged fuel filter, and also considering the ignition control module, crankshaft position sensor, ASD relay, or the computer. The fuel pump was considered less likely given the mileage.
