2002 Chrysler Sebring Oil Pressure Light
You should change the oil & filter and get the oil pressure tested with a master gauge. If the sender is working as it should it is telling you that you have very low oil pressure at idle. If this is the case you will have to get the system checked & tested by someone who fully understands the lubrication system to advise what to do next. If you do have low oil pressure and don't do anything about it, you will run the risk of destroying your engine.
mark (mhpautos)
Suggested Repair
Change the oil and filter, then test oil pressure with a master gauge. If the sender is accurate and pressure is low at idle, have the lubrication system inspected by someone familiar with it. Continued driving with low oil pressure risks engine damage.
Conversation Summary
A 2002 Chrysler Sebring LXi with 97,000 miles shows the oil pressure light at stops or idle, but the light goes out while driving. The owner asked whether debris in the oil system could be the cause and how long the car can be driven. The expert advised changing the oil and filter and testing pressure with a master gauge. If the sender is working, the light indicates very low oil pressure at idle, and the lubrication system should be checked; ignoring low pressure risks destroying the engine.
