Engine Stalls only when AC is on
AMOEBA
  • 15 POSTS
2001 Sebring LXi Coupe, V-6 3Litre, Manual 5 spd, 140,000kms.
Battery died this week. Disconnected terminals and replaced. Prior to battery failure, engine ran great.
After battery replacement the engine would stall when coming to a stop. Thought that maybe it takes some driving to reprogram the onboard computer.
And yes, now the idle is OK(800rpm @ idle).
PROBLEM is that if the AC is on when coming to a stop, the RPM's drop to below 500, and the engine stalls. If I shut off the AC prior to stopping, idle is good, no stall. If I am sitting at a standstill, turn on the AC, the idle will drop, and stall occurs.
Thinking it may be Idle Speed Control Actuator, and possible a few other sensors & controls.
What is unusual is that it all started after battery change.
ANY THOUGHTS!
Aug 16, 2007 at 2:28 PM
  • 75,988 POSTS
[quote:14c1680e94="Amoeba"]2001 Sebring LXi Coupe, V-6 3Litre, Manual 5 spd, 140,000kms.
ANY THOUGHTS![/quote:14c1680e94]
Could be computer relearning--- also could be the ISC or an Idle-up solenoid not kicking in to compensate for the load of the AC .
Aug 16, 2007 at 3:26 PM
AMOEBA
  • 15 POSTS
[quote:5984f1d3e2="rasmataz"][quote:5984f1d3e2="Amoeba"]2001 Sebring LXi Coupe, V-6 3Litre, Manual 5 spd, 140,000kms.
ANY THOUGHTS![/quote:5984f1d3e2]
Could be computer relearning--- also could be the ISC or an Idle-up solenoid not kicking in to compensate for the load of the AC .[/quote:5984f1d3e2]
Computer relearning it isn't, as I've driven for a period of time now, but I will check the ISC & Idle-up solenoid.
:D
Many thanks for getting back to me!!
Aug 26, 2007 at 10:48 AM
