1998 Chrysler Sebring Blower Only on High
MICHAELBUET
Hi! I have a 1998 Chrysler Sebring Convertible - love the car, but it is a difficult car to work on to say the least!! The fan switch only works at full blast - The dealer sold me the resistor assy for it, which should solve the problem, and told me it is located somewhere above the glove compartment - I have taken that apart, and cannot locate it - Also removed the radio and disassembled the heater/fan module from under the radio to see if I could find it... Not in sight. I hope someone can help me and tell me exactly where that thing is.
Thanks!!
Sincerely.
Michael :( :?:
Nov 3, 2007 at 10:28 AM
CHEVY22
  • 1,375 POSTS
hey michael
the resistor is under the glove box , you almost have to get on the floor on your back and look at the lower panels like your looking for waldo but it is there mounted to the kick panels look for the two screws mounted close like on your new resistor, sometimes you have to pull the carpet back too
jim
Nov 3, 2007 at 11:28 AM
Suggested Repair
Locate the blower resistor under the glove box, mounted to the lower kick panel. Look from the floor for two screws spaced like those on the new resistor, and pull the carpet back if needed.
Conversation Summary
The owner of a 1998 Chrysler Sebring Convertible says the fan works only on high and cannot find the resistor assembly the dealer said was above the glove box. An expert says it is under the glove box on the kick panel, identifiable by two closely spaced screws, and that the carpet may need to be pulled back.
