1999 Chrysler Sebring Blower Resistor Blows
GWARD
1999 Chrysler Sebring JXi convertible 145,000 km
The resister block for the blower motor keeps blowing and only high speed is available. Works for anywwhere from 3 days to 2 months when I replace it. Any ideas what might cause it?
Glenn
Dec 12, 2006 at 3:50 AM
BOOTDOG
  • 665 POSTS
alot of times the blower motor will work fine, yet it will short out the resistor. look into replacing the blower motor and resistor at the same time. i found this problem to be common in different makes and models :D
Dec 13, 2006 at 8:57 AM
Suggested Repair
Replace the blower motor and the resistor block at the same time. A motor that still runs can short the resistor and cause repeated failures.
Conversation Summary
A 1999 Chrysler Sebring JXi convertible has a blower motor resistor that keeps failing, leaving only high speed. Replacements last from a few days to about two months. The expert says a blower motor can still run yet short the resistor, and recommends replacing the motor and resistor together, noting this is a common issue.
