1997 Chrysler Sebring Stalls When Hot
PETER INMAN
1997 chrysler sebring w/2.5 v6 150,000 mi. Car shuts off at random must sit approximately 20-30 sec then will restart 1st try this happens often in heavy traffic and seems to happen more when hot outside hooked up too neighbors trouble shoot scanner and nothing wrong so says scanner what say you?
Aug 2, 2007 at 3:27 AM
SERVICE WRITER
  • 9,123 POSTS
You need to troubleshoot when problem is happening. Is it losing spark and or fuel is the question. You can spray carb or intake cleaner into the throttle body to see if it starts from lack of fuel, or use a spark tester to see if there is a loss of spark.
If it is loss of spark, you may be able to use a hairdryer on the ignition control module or pcm to see if the heat affects it.
Aug 2, 2007 at 3:32 AM
Suggested Repair
While the stall is occurring, determine whether the engine is losing fuel or spark. Spray intake cleaner into the throttle body to test for a fuel problem, or use a spark tester to check for spark. If spark is lost, apply heat with a hair dryer to the ignition control module or PCM to see whether heat triggers the failure.
Conversation Summary
A 1997 Chrysler Sebring 2.5 V6 with 150,000 miles shuts off at random, then restarts on the first try after sitting 20-30 seconds. It happens often in heavy traffic and more frequently in hot weather, and a scan found no faults. The expert recommends checking for loss of fuel or spark during the problem and heat-testing the ignition control module or PCM if spark is lost.
