2001 Chrysler Sebring Engine Shuts off
JAPRAY
  • 2001 CHRYSLER SEBRING
  • 6 CYL
  • 142,000 MILES
I just perchase a use car and found each time I place the car in reverse or if I tap the gas padel the engine would shut off but the radio and lights are still on. I tried fuel injection 2 times same deal. I was told maybe the car needs a tuneup, but I would like to know what is causing this issue and I would like to know if I do spend $300-$400 for a tuneup will it fix the problem, Thanks!
Thursday, February 25th, 2010 AT 8:46 PM
  • 109,885 POSTS
If it only happens in reverse, I doubt that a tune up is going to chance it. Has the check engine light ever come on? Have you checked the fuel pump pressure and for vacuum leaks?
Saturday, March 6th, 2010 AT 11:06 PM
