2002 Chrysler Ignition Locked Up
2002 CHRYSLER
BRENDALDWIGHT
My boss has a 2002 Chrysler and the ignition has locked up totally. He cannot even move the steering wheel. What can he do to get it to unlock? Thanks so much for your help!!
BMcVey
Jun 7, 2007 at 7:27 AM
  • 110,251 POSTS
It sounds like the tumbler has gone bd. It will need replaced. To do so you need to remove the steering wheel and part of the steering column. If it has an air bag, make sure to give it at least 20 minutes with the battery disconnected to make sure the air bag doesn't deploy.
Mar 20, 2009 at 9:46 AM
Suggested Repair
Replace the failed ignition lock tumbler. This requires removing the steering wheel and part of the steering column. If the vehicle has an airbag, disconnect the battery and wait at least 20 minutes before starting so the airbag does not deploy.
Conversation Summary
The owner reports that a 2002 Chrysler ignition is completely locked and the steering wheel will not move. The expert says the lock tumbler has failed and must be replaced, which involves removing the steering wheel and part of the steering column. If an airbag is present, the battery should be disconnected and left for at least 20 minutes first.
