Ignition
BIGGIN2005
I was wiring my stereo in my 2003 grand am se and something happened and my ignition locked up i was told there was a plug that has like a plunger inside that if i was to stick a small screwdriver in it would release the ignition but having trouble finding it if anyone could help please do
Sep 17, 2007 at 1:56 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f9729836ea="biggin2005"]I was wiring my stereo in my 2003 grand am se and something happened and my ignition locked up i was told there was a plug that has like a plunger inside that if i was to stick a small screwdriver in it would release the ignition but having trouble finding it if anyone could help please do[/quote:f9729836ea]
HI
IF YOU ARE TO REMOVE THE IGNITION SWITCH
ITS ON THE BACK OF IT
IGNITION SWITCH LOCATED BEHIND THE IGNITION
KEY
THAT PLASTIC THING YOU ARE LOOKING FOR SHOULD BE INSTALLED ON THE BACK OF THE SWITCH
YOU MUSTOF HIT IT WHEN PULLING OR INSTALLING THE RADIO
GOOD LUCK
Sep 17, 2007 at 2:23 PM
