1984 Mercedes 380 SL Ignition Locked
MERCEDES BENZ
RODIP
I have a 1984 Mercedes Benz 380 SL with 156,000 miles on it. It has a 3.8 litre engine. Yesterday I went to start it and the key will not move in the ignition to turn it over - the ignition is locked. I have an alarm system on it, but that doesn't seem to have anything to do with it. The lock just seems frozen. The day before it seemed a little stuck, but I was still able to turn the key and start it. Now it's totally frozen or stuck and I can't start the car. Any ideas?
Your help is much appreciated and so is your time.
God bless,
Melissa P.
Sep 30, 2007 at 12:50 PM
BUZZSAW
  • 1,198 POSTS
[quote:5716bf6059="rodip"]Hello,
God bless,
Melissa P.[/quote:5716bf6059]
the ignition switch is the prob, when locked it has to be drilled out, this is a major job
Sep 30, 2007 at 10:45 PM
Suggested Repair
The locked ignition switch is the problem and must be drilled out. This is a major job.
Conversation Summary
The owner of a 1984 Mercedes-Benz 380 SL says the ignition key will not turn and the lock feels frozen after being slightly stuck the day before. An alarm system is present but does not appear related. The expert says the ignition switch is the problem and, when locked, must be drilled out, which is a major job.
