1983 Mercedes 300CD Ignition Won't Turn
MERCEDES BENZ
MERCEDESMAN
Hello All,
I am another driver enjoying lots of miles on an old mercedes. I have a 1983 mercedes 300CD (turbodiesel). It has 240,000 miles and runs well except for the last month. IF I park the car with the steering wheel turned so that the mercedes logo is vertical, I can always restart the car. IF I park the car with the steering wheel logo horizontal, then it can take several minutes trying to get the key to turn and release the steering lock. Unfortunately the car has been sitting for a month now. I press the brake, and also turn the wheel left and right vigorously with no success. I am parked on a slight incline so Icould let the car roll back if being level :idea: matters. However, if I don't get it started then I will be stuck in the street. Any one had this kind of old car fun?
Jul 10, 2006 at 6:04 AM
DR LOOT
  • 2,311 POSTS
I have had the same problem you are experiencing, the Mercedes ignition switches very complicated, I went to my local key shop, they sold me a special spray for ignition and door locks, I sprayed it in and it fix it, but check your Key it may be warn, if you have your back up key try it, if not you will have to remove the passenger side door handle and have a new key made
Feb 22, 2009 at 2:38 AM
Suggested Repair
Spray a lock lubricant into the ignition switch. Check whether the key is worn and try the spare key. If that fails, remove the passenger-side door handle and have a new key made.
Conversation Summary
The owner of a 1983 Mercedes 300CD cannot turn the ignition key to release the steering lock when the wheel is parked with the logo horizontal. Rocking the wheel no longer helps after the car sat for a month. An expert who had the same problem recommends lock spray, trying a spare key if the key is worn, or having a new key made from the passenger door lock.
