Ignition Question
CHRYSLER SEBRING
RODHA31
Hello I have a 2004 Chrysler Sebring and when I put the key in the ignition, nothing happens. The ignition is locked but the steering wheel turns, and the gear shift is locked and will not move. The ignition switch will not move, the only thing that moves is the steering wheel. What should I do?
Jan 22, 2006 at 4:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will probably have to replace igntion switch or lock cylinder. More information about this issue can be found on our Car Repair Troubleshooting webpage. Just follow the link below and inspect everything stated on the webpage.
http://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
Thanks for using 2CarPros.com!
Feb 8, 2009 at 12:29 PM
