the transaxle was rebuilt with a reman torque convertor and pump. The car was driven 5 miles and burned 2nd clutches. The unit was removed and repaired. on test drive found there was a bind up in 3rd gear after 1 mile. Wiith tranx tester installed I realized the computer was not keeping the second solenoid on which allowes the clutch to apply and bindup in 3rd. I have replaced PCM, MLP, valvebody with new wiring and solenoids. All wiring has been tested for integrity and passed amp flow test.this condition happens after about a mile of driving. It gets worse the longer it is driven the only way to prevent distructoin of the clutches is to put shifter in d2.
Jun 27, 2010 at 7:41 PM
