2001 Chrysler Voyager Hot Weather Shake
Suggested Repair
Check the intake air temperature (air charge temperature) sensor, because a bad reading can keep the computer from adjusting timing correctly in hot weather. Also ohm-test the MAP sensor. Repeated TPS replacements and a throttle inspection have not fixed the hot-weather high-voltage code and shake.
Conversation Summary
The owner of a 2001 Chrysler Voyager with a 3.3 engine reports a check engine light and a slight shake after start in hot weather, with a high-voltage throttle position sensor code. Replacing the sensor and inspecting the throttle body did not stop the problem, which is worse with the air conditioner. An expert suggests checking the air temperature or air charge temperature sensor and ohm-testing the MAP sensor rather than assuming the computer is at fault.
