HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
Grand Voyager
Engine
Oil Pressure Sensor
Replace/Remove
Install procedures for Chrys van oil pressure switch
CBEBOUT
MEMBER
CHRYSLER GRAND VOYAGER
Just don't know if you have to drain the oil first, or you can remove the switch without draining the oil.
2000 Chrys Voyager van - 2.4L 4 cyl engine 137K miles.
Just rebuilt trans @ $2000 bucks. Arggghhh. Guy said the oil pressure switch was leaking oil.
Thanks!
Friday, April 13th, 2007 AT 9:13 PM
BOOTDOG
MECHANIC
No you don't have to drain the oil to change the switch. A little will leak out, but not enough to worry about.
Saturday, April 14th, 2007 AT 9:00 AM
Please
login
or
register
to post a reply.
Related Oil Pressure Sensor Replace/Remove Content
Belts
2000 Dodge Grand Caravan 3.3l Engine. At Least Four Times Now The Serpentine Belt Has Come Off In Wet Weather. This Happened At Least Once...
Asked by
Steven Willingham
1 ANSWER
Pcm
I Need A Picture Of The Inside Of The Pcm, It Has Burn A Circuit On The Pcb, So We Cannot Reed The Numbers On It. We Will Try To Put A...
Asked by
Jennysa
7 IMAGES
2004
The Fan Belt Still Runs When The Car Is Shut Off
Car Is Shout Off. But The Fan Belt Is Still Running And Blowing Air.
Asked by
Dua
2000
2001 Chrysler Grand Voyager Serpentine Belt
Serpentine Belt Came Off - No Power Steering - Howq Long Can I Drive It Without The Serpentine Belt?
Asked by
mloede
1 ANSWER
2001
2001 Chrysler Grand Voyager Timing Belt
Engine Mechanical Problem 2001 Chrysler Grand Voyager 4 Cyl Front Wheel Drive Manual I Need Timing Belt Diagram 2, 5crd Engine.
Asked by
freegass
1 ANSWER
2001
VIEW MORE
Engine Oil Leak
Engine Rattle
Engine Oil Replacement Honda Accord
