radiater fans will not turn off
ADRIANTHOMSON
i have a 1999 chrysler voyager 2L in which the cooling fans will not go off i have pulled the fuse out even taken the leads of the battery can you give me some idea please
Feb 24, 2007 at 3:44 PM
CHEVY22
  • 1,375 POSTS
any lights on at all ,??? have you pulled the relay and try swapping it out with another on in the car yet , it can only be a few things , if you have a check eng light on we need to check the codes , temp sensor could be doing this also , try and isolate it with the relay first
thanks
jim
Feb 24, 2007 at 3:54 PM
