1996 Chrysler Concorde Hard Start
NADEAU.DA
My '96 Chrysler Concorde has been having a lot of trouble starting since I got back home from college. My sister has been using it and has reported that it takes several tries to start it. Whenever I try to turn the key in the ignition, there is a clicking sound and the radio/lights come on, but the engine will not start. Sometimes it takes two tries, others it takes several dozen before the engine will start. How do I resolve this issue?
Aug 6, 2007 at 7:13 AM
  • 75,988 POSTS
[quote:234dd3a650="nadeau.da"]My '96 Chrysler Concorde has been having a lot of trouble starting since I got back home from college. My sister has been using it and has reported that it takes several tries to start it. Whenever I try to turn the key in the ignition, there is a clicking sound and the radio/lights come on, but the engine will not start. Sometimes it takes two tries, others it takes several dozen before the engine will start. How do I resolve this issue?[/quote:234dd3a650]
For a start if it has one ASD relay inspect and test it. This relay is known to power the coil and fuel pump could be bad.
Aug 9, 2007 at 9:16 AM
Suggested Repair
Inspect and test the ASD relay, which powers the ignition coil and fuel pump and may be failing.
Conversation Summary
The owner of a 1996 Chrysler Concorde reports that the car often needs many attempts to start. Turning the key produces a click and powers the radio and lights, but the engine does not start. The expert recommends inspecting and testing the ASD relay because it supplies the coil and fuel pump and could be bad.
