I'm having problems when I try starting my car and has stalled while running.
When I try turing over the car if all the lights on my dash do not show up the engine will not start.
If all the lights show up including the cruise light the car starts and runs fine.
I've been driving down the freeway and all of a sudden all of the dash lights will show up and the car will die.
The car ran great for 2 days after I fully charged the battery and then after resting for 1 day it won't start again. I've changed the fuel pump relay switch but no luck. My mechanic friend tested the spark plugs when it wouldnt start and they were not getting any spark. He thought it was the fuel pump relay switch or the ignition switch. I'm not sure. Please help. Thank you, Kathy
Dec 7, 2008 at 2:07 AM
