Cruise Control runaway
GHAGEN
I have a 96 Chrysler Cirrus LXi and it has 125K miles. It has a V6 and the problem is when using cruise control it will work fine for about 20 to 30 minutes and then the transmission seems to go into neutral without any movement on the shift lever and the motor rpms go way up. Any ideas?
Thanks
Ghagen
May 22, 2007 at 1:21 PM
2CARPRO JACK
  • 11,533 POSTS
only does it when the cruise control is on?
May 23, 2007 at 1:25 AM
GHAGEN
Yes, that is correct.
May 29, 2007 at 10:24 AM
2CARPRO JACK
  • 11,533 POSTS
Does the check engine light come on when this happens? If it does, have the PCM scanned for codes.
May 29, 2007 at 11:22 AM
GHAGEN
the check engine light does not come on.
Jun 4, 2007 at 3:37 PM
2CARPRO JACK
  • 11,533 POSTS
That is going to be something in the trans, I cannot find where the cruise would have any effect on the trans operation in my wiring diagrams. No Tech Service Bulletins or recalls that I can find either.
Jun 5, 2007 at 12:55 AM
