1996 Chrysler Cirrus Cruise Neutral
GHAGEN
I have a 96 Chrysler Cirrus LXi and it has 125K miles. It has a V6 and the problem is when using cruise control it will work fine for about 20 to 30 minutes and then the transmission seems to go into neutral without any movement on the shift lever and the motor rpms go way up. Any ideas?
Thanks
Ghagen
May 22, 2007 at 1:21 PM
2CARPRO JACK
  • 11,533 POSTS
only does it when the cruise control is on?
May 23, 2007 at 1:25 AM
GHAGEN
Yes, that is correct.
May 29, 2007 at 10:24 AM
2CARPRO JACK
  • 11,533 POSTS
Does the check engine light come on when this happens? If it does, have the PCM scanned for codes.
May 29, 2007 at 11:22 AM
GHAGEN
the check engine light does not come on.
Jun 4, 2007 at 3:37 PM
2CARPRO JACK
  • 11,533 POSTS
That is going to be something in the trans, I cannot find where the cruise would have any effect on the trans operation in my wiring diagrams. No Tech Service Bulletins or recalls that I can find either.
Jun 5, 2007 at 12:55 AM
Suggested Repair
Because the check engine light does not come on and wiring diagrams show no cruise-control effect on transmission operation, diagnose the transmission rather than the cruise system. No related TSBs or recalls were found.
Conversation Summary
A 1996 Chrysler Cirrus LXi works normally on cruise control for 20 to 30 minutes, then the transmission seems to go into neutral without shifter movement and engine RPM rises. The problem occurs only with cruise on, and the check engine light does not come on. The expert found no wiring link between cruise control and transmission operation and no related TSBs or recalls, and concluded the fault is in the transmission.
