1998 Chrysler Cirrus Radiator Drain
TOM_K
Where is the radiator drain plug on a 1998 Chrsler sirrus? If there is not one, how do I drain the radiator?
Dec 30, 2006 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
If there isn't one, pull the bottom radiator hose.
Jan 1, 2007 at 12:25 AM
STRATUS98
  • 96 POSTS
There is a drain fitting located on the passenger side bottom corner but if you have the v6 model you will not be able to reach this by hand, you can use a universal joint and socket and a long enxtension to remove it.
Jan 2, 2007 at 12:31 AM
Suggested Repair
Drain the radiator through the fitting at the passenger-side bottom corner. On a V6, use a universal joint, socket, and long extension because the fitting is hard to reach by hand. If there is no drain plug, remove the lower radiator hose.
Conversation Summary
The owner of a 1998 Chrysler Cirrus asked where the radiator drain plug is and how to drain the radiator if none is present. One reply said to remove the lower radiator hose if there is no plug. Another said a drain fitting is at the passenger-side bottom corner and, on a V6, can be removed with a universal joint, socket, and long extension.
