fuel problem
RICHARD123
my 98 chevy stepside 6 cyl. with 100,000 miles turns over but wont start. Fuel pressure is good. i poured a little fuel into the throttle body and it started and promptly stalled when that fuel was gone. I replaced the relay. any suggestions ? by the way...new pump. lines and filter and tank 3 months ago.
Sep 1, 2007 at 8:39 AM
  • 75,988 POSTS
[quote:a451512bc8="richard123"]my 98 chevy stepside 6 cyl. with 100,000 miles turns over but wont start. Fuel pressure is good. i poured a little fuel into the throttle body and it started and promptly stalled when that fuel was gone. I replaced the relay. any suggestions ? by the way...new pump. lines and filter and tank 3 months ago.[/quote:a451512bc8]
Do not feed it with fuel-disconnect the coil wire at coil have someone crank it over while listening to the injector/s is it clicking?
Sep 1, 2007 at 8:46 AM
RICHARD123
[quote:044c924784="rasmataz"][quote:044c924784="richard123"]my 98 chevy stepside 6 cyl. with 100,000 miles turns over but wont start. Fuel pressure is good. i poured a little fuel into the throttle body and it started and promptly stalled when that fuel was gone. I replaced the relay. any suggestions ? by the way...new pump. lines and filter and tank 3 months ago.[/quote:044c924784]
Do not feed it with fuel-disconnect the coil wire at coil have someone crank it over while listening to the injector/s is it clicking?[/quote:044c924784]
hope i am doing this right... thanks for replying ras, if you are referring to whether or not plugs are getting spark, yes, I tested for that, and they are.
Sep 1, 2007 at 8:55 AM
  • 75,988 POSTS
[quote:778d0099aa="richard123"][quote:778d0099aa="rasmataz"][quote:778d0099aa="richard123"]my 98 chevy stepside 6 cyl. with 100,000 miles turns over but wont start. Fuel pressure is good. i poured a little fuel into the throttle body and it started and promptly stalled when that fuel was gone. I replaced the relay. any suggestions ? by the way...new pump. lines and filter and tank 3 months ago.[/quote:778d0099aa]
Do not feed it with fuel-disconnect the coil wire at coil have someone crank it over while listening to the injector/s is it clicking?[/quote:778d0099aa]
hope i am doing this right... thanks for replying ras, if you are referring to whether or not plugs are getting spark, yes, I tested for that, and they are.[/quote:778d0099aa]
Find the fuel injector/s and listen to it, is it clicking-if not investigate and test the crankshaft position sensor
Sep 1, 2007 at 9:03 AM
RICHARD123
ras, I cant find the fuel injectors ! there dont seem to be any ! my engine size is 4.3. maybe didnt use them for that size engine ?
Sep 2, 2007 at 5:10 AM
  • 75,988 POSTS
[quote:f8f8bdde3f="richard123"]ras, I cant find the fuel injectors ! there dont seem to be any ! my engine size is 4.3. maybe didnt use them for that size engine ?[/quote:f8f8bdde3f]
Sorry, if its a 4.3L and don't have a carb looking-its on the bottom of the IMTV they call it CPI or Spider center of engine top.
On the back, driver side you'll see the in and out hoses and also the fuel pressure tap -disconnect the closes to you at the driver side when looking at it-check for fuel while key is On. Do you have fuel?
Sep 2, 2007 at 7:35 AM
