1990 Chevy C1500 No Start No Fuel
CLOCO1930
  • 6 POSTS
i have a 1990 chevy c1500 , my car started fine earlier in the day. but now it wont start, i have changed my fuel filter and still it wont start and i dont know what the problem could be.
Jun 30, 2007 at 8:36 AM
NEWBURG
  • 20 POSTS
Did you check for spark? yet or did you change the filter cause you wern't getting any fuel?
Jul 2, 2007 at 1:41 PM
GBGTEXAS
  • 46 POSTS
[quote:de44d8f4c9="cloco1930"]i have a 1990 chevy c1500 , my car started fine earlier in the day. but now it wont start, i have changed my fuel filter and still it wont start and i dont know what the problem could be.[/quote:de44d8f4c9]
When you turn the key to the ON position, do you here the fuel pump in the tank come on for about 2-3 seconds. If you do, check spark. If not, you may have a bad fuel pump.
Jul 2, 2007 at 2:34 PM
CLOCO1930
  • 6 POSTS
ok i have a 1990 chevy 1500 305 size engine, the car isnt gettin fuel to the carborater i changed the fuel pump and the filter and the car still wont start what should i do next
Jul 13, 2007 at 5:04 PM
  • 75,988 POSTS
[quote:e2697b9f8a="cloco1930"]ok i have a 1990 chevy 1500 305 size engine, the car isnt gettin fuel to the carborater i changed the fuel pump and the filter and the car still wont start what should i do next[/quote:e2697b9f8a]
Do you hear the fuel pump come On with key in On position-if so look for ignition spark-if not check the fuel pump relay.
Jul 14, 2007 at 2:38 AM
Suggested Repair
With the key on, listen for the fuel pump to run briefly. If it does not prime, check the fuel pump relay. If it does prime, check for ignition spark.
Conversation Summary
The owner of a 1990 Chevrolet C1500 with a 305 engine says it started earlier but now will not start. After replacing the fuel filter and fuel pump, fuel still does not reach the carburetor. The expert advises listening for pump prime with the key on, then checking the fuel pump relay if it does not run or checking for spark if it does.
