ALONG WITH THE VACCUME LINES . I DONT NOW WHAT ELSE TOO THE DISTR CAP IS NEW NEW ROTOR BUG ALMOST EVERYTHING IS NEW. PLEASE HELP'''''
89 chevy silverado C\K 1500 will not start ?
Suggested Repair
If the engine sounds like it wants to start, the ignition timing may be slightly retarded. Rotate the distributor a little counterclockwise and try starting again. If it sounds closer to starting, continue small adjustments until it runs, then disconnect the ESC and set the timing properly.
Conversation Summary
The owner of a 1989 Chevy Silverado C/K 1500 with a newly rebuilt 350 reports that the engine cranks and sounds like it wants to start but will not. Fuel delivery to the throttle body and spark are present, and the distributor rotor appears aligned toward the number one piston at top dead center. Wiring, vacuum lines, the distributor cap, and rotor are described as new or correct. The expert advised that timing may be slightly retarded and recommended turning the distributor slightly counterclockwise, continuing small adjustments until it runs, then disconnecting the ESC and setting the timing properly.
