1985 Chevrolet Truck Fuel Cutout
E40WATER12
  • 522 POSTS
My friend just installed rebuilt SB 350 into his 85 edlebrock 750 cfm 4 barrel carb chevy pickup 4x4, Fresh tuneup / air filter / Fuel filter /etc. While out on a test run the truck would accelerate exc, No misses, Then after around 5-10mins of driving, Then motor would start to choke and cut out, Then shut down, No fuel is present in the line,Also all 8 cyl's have had compression test done, they are all reading above 150 psi, Also before may add, This engine before had this issue in the other truck, After the old mechanical pump, was replaced with the electrical pump it never did that. even well over 1 hour of driving. Now with back to the first question, The motor has went back to a mechanical H.O. volume fuel pump, Now its not sucking any fuel into the filter or fuel line, I was thinking something to do with the cam lobe or timing chain gear?
any Idea's?
thanks
May 21, 2007 at 11:34 AM
E40WATER12
  • 522 POSTS
Ok after a long process of trouble shooting, Inspecting, I found a problem with the rubber hose that connects sending unit on the fuel tank was cracked, In which allowed air to enter into the fuel line. Fixed the hose, No more problems with stalling or cutting out.
May 26, 2007 at 4:51 PM
Suggested Repair
Replace the cracked rubber hose between the fuel-tank sending unit and the fuel line so air cannot enter the fuel system.
Conversation Summary
A 1985 Chevrolet pickup with a rebuilt small-block 350 and mechanical fuel pump ran well briefly, then choked, cut out, and shut down with no fuel in the line. Compression was good, and an electric pump had previously prevented the same issue. Inspection found a cracked rubber hose at the tank sending unit that let air into the fuel line; replacing the hose stopped the stalling.
