2006 Chevrolet Truck E85 Wrong Fuel
RESPONDSOON
  • 6 POSTS
I put E85 in my 2006 truck with out checking out all the details...5.3L Vortec. If get the gas pumped out and put regular gas in will my truck run ok?
Jun 2, 2007 at 8:51 PM
SERVICE WRITER
  • 9,123 POSTS
IS there any runninbility problems now?
I would think adding octane boost would be okay for one tank full. Changing the fuel filter afterwards would be a good idea as well...basic maintenance anyhow.
Jun 2, 2007 at 8:55 PM
RESPONDSOON
  • 6 POSTS
no problems with the way it runs just yet
Jun 2, 2007 at 9:01 PM
RESPONDSOON
  • 6 POSTS
yeah i check the site before i went but there were more details that i missed at first glance like the vin number
Jun 2, 2007 at 9:02 PM
RESPONDSOON
  • 6 POSTS
So my check engine light is on...Should i expect any major problems?
Jun 2, 2007 at 9:12 PM
SERVICE WRITER
  • 9,123 POSTS
The CEL will likley show a lean code because the E85 is less powerful, thus why I mentioned the octane boost.
Jun 3, 2007 at 1:52 AM
RESPONDSOON
  • 6 POSTS
thanks for the help
Jun 3, 2007 at 2:21 AM
DARRIL
I have a 2002 chevy truck I some times get a check engine light when I use regular unleaded. The lcode it gives is for the knock sensor. All I have to do is run a tank of super unleaded and it will go away. You probably got the check engine light because of the low octane.
Jul 20, 2007 at 8:29 PM
SERVICE WRITER
  • 9,123 POSTS
The pcm expects a certain octane. IF you have problems with the CEL and you are using the correct octane, you have a non-fuel octane problem.
Jul 21, 2007 at 3:22 PM
Suggested Repair
Add octane boost for one tank, then refill with the correct regular fuel. Replace the fuel filter afterward. A lean check-engine code is likely from the lower-energy E85; if the light remains after using the correct octane, diagnose a non-fuel problem.
Conversation Summary
The owner put E85 in a 2006 truck with a 5.3L Vortec and drove about 30 miles, then asked whether pumping it out and refilling with regular gas would be enough. The truck was still running normally, but the check engine light came on. The expert said octane boost should be acceptable for one tank because the computer expects a certain octane, and recommended changing the fuel filter. The light was expected to indicate a lean condition because E85 has less energy. A later comment about a different 2002 truck and a knock sensor was noted as a separate octane-related experience.
