Chevy Truck no spark
SAUTHOFF
  • CHEVROLET TRUCK
I am restoring my 77 chevy 3/4 ton pickup. I replaced the engine last fall and tried to start it. I have not rebuilt the carb then so I got it to pop off and run for a few seconds with starting fluid. This spring, I tried to start it with everything hooked up and it won't gererate a spark. I have replaced the distributer cap and rotor, spark plugs and wires and I think the coil. Can't remember. It's an eletronic ignition and was wondering what could be causing the problem of no spark. I took out a plug and grounded it to the frame to find out that that was the problem, so timing wouldn't matter. I don't want to just start buying parts until I hit the right one.
Friday, March 30th, 2007 AT 3:50 PM
HEI-check for power at the red wire. Power there test the coil and the magnetic pick up in the distributor.
Tuesday, April 3rd, 2007 AT 1:02 AM
