97 Chevy truck NO Spark
LB3
My 1997 Chevy ct1500 5.0 has no spark. It died on the road towed it home turns over no start.I have checked all fuses, checked power to both in truck and under hood fuses box fine, checked power to coil has power, changed coil, no spark, changed computer ( bought used one ) also changed the chip in computer with the one I had orginally and also changed CPS still no spark and I checked all my grounds and connections ..Any clues loosing my mind
Jan 4, 2006 at 3:16 AM
HOTWHEELSGMC
  • 31 POSTS
if it's turning over and just not starting, could be as easy as a clogged fuel filter or fuel pump. try spraying some eingine start spray in the carburator, if it starts for a second then dies, it's not getting any fuel.
Jan 19, 2006 at 11:54 AM
