back up lights
BRADCRABB
i have a 1984 chevy truck half ton and the back up lights don't work.there is no power at the bulb socket. can i wire them directly to the fuse block??
Sep 19, 2007 at 8:16 AM
WRENCH
  • 57 POSTS
Not a good idea, did you check the reverse switch on the transmission. A lot of times that is the problem.
Sep 19, 2007 at 9:02 AM
BRADCRABB
[quote:1414d0fea9="wrench"]Not a good idea, did you check the reverse switch on the transmission. A lot of times that is the problem.[/quote:1414d0fea9]i did check the switch on the trany. there is no power there also. i had the steering colum repalced with one from a 87 model chevy trk.. is there a diff,???
Sep 19, 2007 at 11:56 AM
WRENCH
  • 57 POSTS
Could be the problem, you could try this follow hot from the switch and see ware it goes, I believe it needs a switched 12v power supply to the trany backup switch, maybe you can do something there.
Sep 19, 2007 at 2:24 PM
