how can i find out what is drawing from it?
joe
Disconnect the negative battery cable and connect a 12-volt test light between the negative battery post and the cable. A faint glow can be normal for the clock or computer; a bright glow indicates a large drain that should be corrected. Pull and replace fuses one at a time until the light goes out to identify the circuit, and hold the door-jamb interior light switch in so the lights stay off during the test.
The owner of a 1994 Chevrolet truck with a 350ci engine says a new battery keeps losing its charge and asks how to find the draw. The expert describes a test-light parasitic drain check: connect the light between the negative post and the disconnected cable, then pull fuses one by one until the light goes out to isolate the circuit, while holding the door-jamb switch so interior lights stay off.
