1985 Chevrolet Truck No Spark
DOCTORJELLY
I accidently hooked up my friend's battery backwards. What could it have fried?
It is an '85 Chevy 1/2 ton with a 305.
Also, the altenator sent up a huge spark when both terminals were hooked up.
May 24, 2007 at 3:57 PM
E40WATER12
  • 522 POSTS
Could have popped a few couple of fuses, Just try to hook up the terminals properly, See what happens.
good luck.
May 24, 2007 at 7:12 PM
DOCTORJELLY
Tried, this happened almost a week ago. It turns over no problem, but we're getting no spark from the plugs so it won't start... After re-timing it and still not working, we replaced the plugs, wires, cap, and rotor, but to no avail. One of my other buddies thinks it's the ignition control module...
I've checked a couple of the fuses in the block inside the cab, but not all of them. Are there any inline fuses, or another fuse block somewhere that I'm not seeing?
*Edit* And what about the computer? Or were there cumputers on that old of a rig?
May 24, 2007 at 8:20 PM
  • 75,988 POSTS
[quote:be8ddbb49c="DoctorJelly"]Tried, this happened almost a week ago. It turns over no problem, but we're getting no spark from the plugs so it won't start... After re-timing it and still not working, we replaced the plugs, wires, cap, and rotor, but to no avail. One of my other buddies thinks it's the ignition control module...
*Edit* And what about the computer? Or were there cumputers on that old of a rig?[/quote:be8ddbb49c]
Start by checking all your fusible links maybe at the starter or within the batt. pos. cable or a power distribution and then check all the mini fuses.
May 24, 2007 at 11:39 PM
DOCTORJELLY
Ok, it turned out it was the ignition control module, so we got the little beast running again.
Thanks for the help e40water12 and rasmataz!
May 25, 2007 at 3:35 PM
Suggested Repair
After a reversed battery connection causes no spark, check all fusible links (starter, battery positive cable, or power distribution) and mini fuses. If cranking is normal but there is still no spark after ignition parts are ruled out, test and replace the ignition control module.
Conversation Summary
An 1985 Chevrolet half-ton with a 305 would not start after the battery was connected backward; it cranked but had no spark, and the alternator sparked when both terminals were connected. Plugs, wires, cap, rotor, and timing did not fix it. Experts advised checking fusible links and all fuses. The owner later confirmed the ignition control module had failed and replacing it got the truck running.
