1984 Chevrolet Truck Backup Lights
Suggested Repair
Do not wire the backup lights directly to the fuse block. Trace the circuit for switched 12-volt power to the transmission reverse switch; the 1987 steering-column swap may have interrupted that feed, so restore the switched supply rather than bypassing the switch.
Conversation Summary
The owner of a 1984 Chevrolet half-ton truck says the backup lights have no power at the sockets and asks about wiring them straight to the fuse block. The expert advises against that and points to the transmission reverse switch. The owner reports no power at that switch either and notes the steering column was replaced with one from a 1987 Chevrolet truck. The expert says that swap may be related and recommends tracing the hot feed, which should be switched 12-volt power to the backup switch.
